1. dy87chf
  4. Thursday, 16 May 2024
When scanning our website for ADA compliancy - https://landprollc.us/, the menu items that have child items are failing. The report says:
Elements that behave as buttons but are built using other tags such as span, div, a or others, should include a "role" attribute that equals to "button".
Failed Elements:
<a href="#" onclick="dodajAktywne(this)" >About<span class="parent-indicator j51-inline-icon" aria-hidden="true"><svg aria-hidden="true" focusable="false" class="svg-inline--fa fa-chevron-down fa-w-14" role="img" xmlns="http://www.w3.org/2000/svg" vi...
<a href="#" onclick="dodajAktywne(this)" >Services<span class="parent-indicator j51-inline-icon" aria-hidden="true"><svg aria-hidden="true" focusable="false" class="svg-inline--fa fa-chevron-down fa-w-14" role="img" xmlns="http://www.w3.org/2000/svg"...
<a href="#" onclick="dodajAktywne(this)" >Seminar<span class="parent-indicator j51-inline-icon" aria-hidden="true"><svg aria-hidden="true" focusable="false" class="svg-inline--fa fa-chevron-down fa-w-14" role="img" xmlns="http://www.w3.org/2000/svg" ...
<a href="#" onclick="dodajAktywne(this)" >Media<span class="parent-indicator j51-inline-icon" aria-hidden="true"><svg aria-hidden="true" focusable="false" class="svg-inline--fa fa-chevron-down fa-w-14" role="img" xmlns="http://www.w3.org/2000/svg" vi...
These menu items have role="img". I think this should be role="menuitem". Can this be fixed in the templates? Also, can you tell me what file I would need to modify to make this change in the meantime? We are using the Emani template.
Email sent with credentials. Thank you.
Just received an email saying that my email to [email protected] was undeliverable.
Strange. Could I ask you to resend? Please cc [email protected]
Resent, thank you.
I have amended your template menu override to include the role attribute as described.
Great, thank you. Can you confirm it was just these two files that were modified:
templates/j51_emani/html/mod_menu/default_component.php
templates/j51_emani/html/mod_menu/default_url.php
Yes, just these 2 overrides have been updated.
Thank you. Will this be something that is added to future template releases, or will I need to apply these overrides after any updates?
We are still seeing some compliancy failures on our menu.
1) Menus should be built using the HTML5 "nav" element or include a "role" attribute set to "menu" or "navigation" to indicate a navigation landmark for screen readers - it looks like nav is being used for the desktop menu but not for the mobile menu.
2) Menu items that have a dropdown should include an aria-haspopup="true" attribute.
3) Menu items that have a dropdown should include an "aria-expanded" attribute set to "false" by default, which changes to "true" when the dropdown is opened, and back to "false" when closed.
Please see the attached screenshots for the failures.
Attachments (3)
