1. HanvdG
  3. Monday, 09 September 2013
Hi Ciarán,
I have some problems with the menu items longer than three items. When I make more items, they are 'hiding' behind the slideshow area or after the content area, and I can't reach them. Also problems with subitems, which I can't reach (not clickable).
Pleas take a look at:
http://hanvandegraaf.nl/index.php/en/mainmenu, and hover over the item "Motorhome" I made there some dummy items which shows my problem. I can't reach 'Dummy1' and Dummy 2 and also not the subitems from VW Westfalia item and from Dummy1 (Dummy1.1).
I hope you can help me solving this.
Thank you!
Han
Hi Han
There appears to an extension conflicting with the dropdown menu script. If you wish you can send us temporary administration access to your Joomla installation to info@joomla51.com and we will try and locate the extension for you. For our reference please paste a URL to this post in your email.
Hi Ciarán,
I will send you an email with login details.
Thanks,
Han
Thank you Han
You have an incredible amount of extensions installed making it difficult to pin point any extensions causing problems. Having this amount of extensions installed can cause a security risk as well as conflicts with other extensions. Could I ask you to try uninstalling any extensions (Extensions -> Extension Manager -> Manager) which yo do not intend to use on your final site.
We also appear to be getting a large number of 404 error across your site including the EN homepage.
Hi Han
Your menus should be now working correctly. After going through all your extensions the solution turned out to be your menu modules missing moomenu in the Menu Tag ID field in your menu modules parameters. This Menu Tag ID is needed to call the dropdown script.
Thanks a lot for your help!
Hi Ciarán,
Did you have time to look at my other problem with the sidecol/b and slishow appearing on not selected pages?
I hope you really will find a solution for that, it is bothering me a lot, so help will be appreciated ! :)
Greetzz,
Han
Hi Han
Would you have a URL to a page where you wish to remove the module in the sidecol-b position?
