  1. karmaboat
  3. Monday, 08 April 2024
I have a website running with Bianca, the main menu is causing me some problems, there is an icon, text and dropdown arrow for the menu items that have subcategories, the problem is that on desktop the 3 things are stacking on top of each other and not in a line and I can't find out how to make them display in a line rather than stacked, please could you point me in the right direction.
  1. http://karmaboat.com
Replace me with the text you want to insert...To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.hornav>ul>li>a, .hornav>ul>li>span {
white-space: nowrap;
Fixed thanks!
