1. z0r0z
  3. Friday, 30 July 2021
Can I use the bar under the module heading elsewhere, for example for articles or from a menu heading? If so, what is the easiest way to do this?
Best regards
Would you have a URL to an example of an element you wish to add the bar to?
Presuming you wish to add it to a H1 heading, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
h1::before,
h1::after {
position: absolute;
bottom: 0;
left: 0;
height: 4px;
content: '';
opacity: .8;
h1::before {
background-color: rgba(0,0,0,0.25);
right: 0;
h1::after {
background-color: var(--primary);
right: calc(100% - 70px);
