1. ip mann
  4. Thursday, 30 May 2024
Hallo!
I don't want to display the dropdown arrows from the items in the hornav menu. Where can I set this?
Replace me with the text you want to insert...To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.hornav ul.menu .parent-indicator {
display: none;
Thaks Ciaran!
I inserted this code snippet in CSS. It doesn't work.
Unfortunately, I have further problems:
2. The elements of the registration form are arranged horizontally instead of vertically.
3. I inserted the main menu in sidecol 1b. The menu items are, of course, spaced apart at different distances.
display: none;
It didn't work in custom CSS. I tried it out in custom code - it works!
Thanks!
For my second problem I once again inserted the following in custom code (it didn't work in custom CSS):
.com-users-login {
display: flex;
flex-direction: column;
and now the item elements are arranged vertically.
P.S. I only have rudimentary CSS and HTML knowledge, hence the experimentation
