1. Kliekske
  3. Sunday, 01 June 2014
I'm using the Brooklyn template for a new website.
My problem is that the top menu is not shown on the homepage when I look at the site on a tablet (iPad in my case)
When I navigate to another page using the footer menu than the top menu appearce in the top right corner.
Does anybody know how to fix this problem?
Thanks already!
The sites URL is: http://www.cafetariajaco.nl
There appears to be a Javascript conflict on your homepage. Could you ensure that jQuery is disabled in your slideshow modules parameters as this is already loaded by Joomla.
When I disable jQuery then the top menu appears on the home page, but the slideshow disappears?
Is there a way to fix this?
May I suggest re sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I've already solved the problem by using another image slider module (ari image slider).
Thanks for pointing me in the right direction ;)
