1. pat02
  4. Saturday, 25 November 2017
I did enter a slogan text, but it is not visible in the frontend. I even did check the source code, but no slogan text there.
How can I add a slogan text?
Thank you very much!
Template: Maya
Joomla: 3.8.2
Patrick
Hello Ciarán
I updated the template and did testing. Works fine!
Thank you very much for adding this! :-)
Patrick
Hi Patrick
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will make this amendment for you. For our reference please paste a link to this post in your email.
Hi Patrick
By default the slogan text will only appear if the Logo image option is disabled. Is this the case that you want the slogan to appear below a logo image?
Hello Ciarán
Yes, I need the slogan text below the logo.
Thanks!
Patrick
Hi Ciarán
I have the website on localhost, not online yet.
Anyway, hacking core files of the template will result in losing the changes on next template update.
Nevertheless, I have done so (please see attached file).
Maybe you want review my changes and add them to the Maya template? :)
Thank you very much.
Patrick
Hi Patrick
Thank you for sharing your solution. We have updated our Maya template to allow the display of both a logo image and slogan text as suggested.
