I'm using Clarity for a website and I have another few questions for you:
1: I would love to be able to style a row of linkhover modules with a description under the picture and a readmore button at the bottom, the same way as they appear in the Substance homepage. Is this possible at all or is it a specific feature of the Substance template (in which case you can probably earn some more money off me :laugh: )?
2: Is it possible to place the search box on the same line, with the same size and height, as the breadcrumbs? I've tried to simply create a Search module and choosing position 'breadcrumbs', but the module size is different from the Breadcrumbs, and they display unevenly.
And how can I add a thank you for helping me out on the installation issue with the Link hover module? ...I was happy to see I wasn't the only one!
Kind Regards,
Marjolein
