1. vincebodie
  4. Thursday, 26 March 2026
Have a look at this site: https://surflounge.art/
I've shown the site to a number of people, and what I've noticed is that the header images don't load right away, but the main logo and menu right below it load first over a black background and most people scroll down before seeing them. I want people to see the images first before scrolling past them. Is there a way to do this?
I removed JCH Optimize from all websites quite a while ago; it was causing problems with several other extensions. I then switched to Viktor Vogel's Easy Performance Booster - Kubik Rubik.
Have you enabled "lazy load" somewhere, and can you disable it?
The main issue seems to be that the slider is not a separate module but is built into the template, and there is a setting for transition time that applies equally to all slides.
In other sliders I have used (think DJ Image Slider for example) you can set the transition time independently for each slide, so I think in that case I could set the time for the first slide to zero which would make it load right away.
I did discover that I had uploaded full resolution images (4928px) for some of the images including the first one, so I resized them all down to 1900px wide.
I also use JCH Optimize on this site and enabled loading of WEBP images and also the sprite generator which seem to have helped. There are lazyload settings in that component but I don't have it enabled.
One other thing I tried was adding the first slide as the background for the header area in the css:
#header_bg {
background: url(../../../images/backgrounds/beats-and-bites-20250215-df0_1339.jpg);
However this created a weird shift when the first slide loads, so I gave up.
Anyhow I think it's better now and I've spent enough time on it! :p
Okay, then best of luck with the implementation ;-)
These days, JCH Optimize creates more problems under current Joomla versions than it solves. You might disable it for a test.
