1. mediafrog
  4. Saturday, 10 May 2014
hi ciaran
on my new page
http://www.psizentrumbasel.ch/preview/index.php
I have one main article which should be shown on the mainpage.
the home-menu is a category blog.
and the main article doesn't appear on the mainpage.
so what do I wrong?
regards
grit
Hi Grit
Can you confirm that the article is set to the same category as your category blog menu item?
If you only intend to display a single article your best option would be to use a 'Single Article' menu item for your home page.
hi ciaran,
ok, this is good to know.
but how is it when the home-menu links to a component? I want to show a event-component on the main page under the main article. do I have to put the "welcome main article" in the module position ContentTop-A or is there another solution?
regards
grit
Create a menu item to your component and set 'Default Page' for that menu item to Yes.
