1. nickymcn
  3. General
  4. Thursday, 22 February 2018
I have just discoverd that the slider and header text are not responsive on a mobile phone. I have looked for the code to fix this issue but as yet unable to find anything to make this work properly or even if it does.
  1. http://www.dhmjournal.com
Thanks so much it worked.
Awesome support.
  2. General
If the above CSS is effecting anything besides your logo then I suspect syntax error. Have you definitely copied the CSS exactly as it appears above? Tried placing it at the end of your Custom CSS field?
  2. General
I have put the code in the custom CSS and it has fixed the header part to resize on a mobile phone but then it removes the styling for other modules I have created throughout. I also cannot get the images in the slider which is included in the template options to render responsive in certain media. I have tried alot of things? Please anyone?
  1. http://www.dhmjournal.com/
  2. General
  3. # 3
Firstly ensure that the Responsive Layout option is enabled in your template settings (General -> Responsive Options).
To reduce the size of your logo text on smaller screens you can also add the following to the Custom CSS field (General -> Custom CSS)...
Edit to taste
.logo h1 a {
font-size: 42px;
  2. General
  3. # 4
I have updated my template and still the issue is not resolved for a mobile device. Can anyone help out?
  2. General
  3. # 5
