Hi Ciaràn,
is it possible to change color of the icon thet open the mobile menu? (I mean the 3 lines stacked icon or hamburger icon whatever you call it)
On Magnolia standard it is light gray on gray, difficult to see.
Many thanks and regards.
Which mobile menu are you using. For the slideout version you will find an option to set the icon color via the 'General -> Responsive Options tab of your template settings.
