1. cuervo
  3. Tuesday, 23 January 2018
Is there a way to remove the logo container and move the rest of the content up?
The bottom border of the header image(s) is oblique. Is it possible to make it horizontal?
Thanks.
Presuming I understand you correctly try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
#header {
display: none;
That was a little too much, I still need the top navigation.
To just hide the logo you can use the following instead....
#logo {
display: none;
For the horizontal bottom border you can also add the following...
#content-outer::after {
display: none;
Both issues solved, thanks a lot.
