1. inosof
  3. Sunday, 25 October 2015
I found Madison a very attractive template. Hence I moved from Liefstyle to Madison
There are a few things I'd like to know. Here's #2:
I'm not sure if it is the body_bg or the content-outer. But I'd like to remove that container so that the picture in the background continues to be shown regardless how far down I scroll.
Thanks,
ino
Hi Ino
For this area you can also add the following...
#container_base, #container_base::after, #container_footermenu, #container_copyright {
Thanks Ciarán.
This addresses the big one. There is a small band of slanted black band at the bottom of the article in the background. For the life of me, I cannot find the container. Can we make this transparent too?
ino
Hi Ino
Presuming I understand you correctly, try adding the following to the Custom CSS field of your templates parameters...
#content-outer, #header_bg::after {
background-color: transparent !important;
