1. Werner
  4. Tuesday, 15 December 2015
Hi Ciarán,
the menu item "zimmer" in the main menu does not work on mobile devices. I tested it with iphone and ipad. Nothing happens when it's clicked upon.
What's going wrong?
URL: kerschbaumerhof.com
Thanks for your help, Werner
Hi Ciarán,
you made my day :-) !
Thank you very much!
Werner
Hi Werner
Presuming I understand you correctly try adding the following to the Custom CSS field of your templates parameters...
.slicknav_menu .slicknav_nav ul {
display: block !important;
Hi Ciarán,
thank you, it's resolved so far. But the solution is not quite what I want. The user should see ALL menu-links when opening the menu-button like here: http://www.herzschule.org. Maybe I find a solution for that.
Nevertheless, thank you for your patience!
Werner
Have you since resolve this issue? Your 'Preise / Extras' menu item appears to be linking without issue.
now the menu-button "zimmer" works, but the submenu-button "Preise" is not clickable any more. Any solution?
Brgds, Werner
You could try setting the following in your templates ../templates/j51_madison/js/responsive-nav/responsive-nav.js to true which will leave the parent link text clickable (open dropdown by clicking the remainder of the button)...
allowParentLinks: true,
