1. angelaplath
  3. Tuesday, 22 December 2015
when I cxlick the Add Header Background Image(s) the screen becomes black whithout retourn. In the Styling list of the template is a bottom COM_TEMPLATES_header_slides_modal_FIELDSET_LABEL between General Styling and Menues, and there is a Bottom COM_TEMPLATES_list_templates_modal_FIELDSET_LABEL between Social Media Icons and Custum css. Both of theese bottoms do nothing. What shall I do ?
This field of the templates parameters uses the 'repeatable' Joomla field type (https://docs.joomla.org/Repeatable_form_field_type). This field type has been noted as having some issues on earlier versions of Joomla 3.x (https://github.com/joomla/joomla-cms/issues/5868). Please ensure you are using the latest version of Joomla which should hopefully resolve this issue for you.
sadly I habe joomla 3.4.7
I can not select any bachground-image, also in the modules I can not selct an image. I have Calibra on the same server with the same Joomla-version and it is perfect with the choosen bodybackground-image. I bought Madison because I wantet to set the very nice Header Image or Header Image-show on my page.
I hope anybody can help me, thank you for reading my english.. and thank you for any solution
Angela
Hi Angela
Hello ciaran,
Now inserting background-picture into the header runs with a trick. I change desktop-view to very small so that I hardly can read anything. I go to Extensions ->Templates ->Styles and ckick on the List/Add Background-Images bottom. Then appears a small box on top in the black bachground and I can select my header images. This works!!. When I save my settings in Template Edit Style then on right site the background for styling is a quite different one, for only less than one second.
Angela
Hi Angela
Thank you for the update and for sharing your solution.
I would also add that changing your administration template to the default 'Isis' should also resolve this issue. The 'Hathor' Joomla template is not fully compatible with some of the newer Joomla field options.
thank you very much for the advice to take Isis!! All runs perfect now!! :) :) :)
Thank you for spending your time!! (I am sorry I did not had the idea of changing administrator template)
Angela
Excellent!
Thank you for the update! :)
