How could I reduce transparency of the active menu items at hornav and adding some colour or something to the background of each active li, so selected item is evident.
Thanks in advance.
Regards,
Juan
Hi Ciarán,
Thanks for your reply.
That does the trick, but it also darkens the dropdowns. Is there a way that the code only affects hornav main items, and not dropdowns also?
Hope you can help.
Thanks in advance.
Regards,
Juan
Hi Ciarán,
I've replaced the previous code by the new one, although I'm still getting the dropdown items darkened.
I attach an image, so you can see what I mean.
Thanks in advance for your help.
Regards,
Juan
