1. Agabby
  4. Wednesday, 17 December 2014
Ciaran,
OMG! I do not know what I did wrong. UGHHHH.. :angry: I've designed three different templates from (J51 Cashmere) main template. All have different backgrounds, etc... All but one (home menu) has a different menu design. I was playing around with the main menu items, articles, etc., module assignments, etc... and I have no idea what I did.
One of my menu items has taken on the look of the home page. For example menu "Look Inside" is using the "Home Page" template and menu design.. What the heck did I do? I published, unpublished and published again.
Ive checked both template menu assignments and they are correct. Everything is in place..
The template still exists, the assignments are correct. I should have just left everything alone.. UGHHH.. Your help is greatly appreciated..
April
Hi April
THank you April
I believe the issue is related to your menu item type. For your 'Look Inside' menu item you are using the 'Menu Item Alias' menu item which is used to link one menu item to another which can cause confusion when assigning a template style (Menus -> Main Menu -> Look Inside). I'm presuming this instead should maybe be a 'Single Article' menu item type?
For further details on this menu type check out.. https://docs.joomla.org/Help33:Menus_Menu_Item_Menu_Item_Alias
