1. modiglianibasket
  3. Sunday, 09 September 2018
Hi!
I purchased Hayley template.
At the moment I do not want to use an image logo, so I use logo text instead.
Unfortunately the logo text is not responsive. So i put the css custom code, in the responsive option, as in the attached images. But it seemes not to work.
Another problem is that I see the menu ONLY in desktop mode!
Could you please help me?
Best regards...
Gae
Hi Gae
Hi Ciaran.
Maybe I fixed the issue, but I don't know if it's the right way.
I put as Logo Text Size a number in % (eg 100%).
http://www.studiopaglioni.it
Anyway, I would like enlarge the high of the header as in the attached image.
Do you think that it is possibile?
Thanks so much!
Best Regards,
Gae
Hi Gae
Edit to taste
.logo {
padding-top: 80px;
padding-bottom: 80px
