Hi guys,
some time ago i bought the template j51_endeavour.
Now i have a problem to use the {loadposition xxx} command to add an module.
Some modules are working and some not, specially i want to have this module:
http://www.wdmtech.com/commercial-module/mod_hex_google_chart.zip
I tried the loadposition command with the standard template on a fresh Joomla 2.5.20 installtion, everything is fine, when i change the template to j51_endeavour the module does not load - all i can see is the title of the module but not the content.
Maybe you can update the one or the other line in the template files
- power87
- Wednesday, 04 June 2014
May I suggest the 'Modules Anywhere' extension which is a common solution to any loadposition issues...
http://extensions.joomla.org/extensions/core-enhancements/coding-a-scripts-integration/embed-a-include/6402
i am trying the whole thing on a fresh Joomla 2.5.20 installtion.
With the standard template is everything fine, when i switch to your template i cant see the content of the module but the module title is viewable.
Its 100% reproducable, i guess its a small codebug or a javascript conflict but i am not a programmer so i cant solve it by myself.
The issue appears to be related to some of the changes you have made to the templates index.php. Reverting everything in your templates index.php up to the closing
</head>
to the template original resolves the issue. Did you notice this issue appearing when making any particular changes to your template index.php?Ciarán
thx i took a deeper look to the head area and was able to find the line.
I used this line to remove a part of code which ends in a console error cause of mootools, sadly this line also removed the Google Charts code.
Maybe someone can help me to modify the code to keep the following lines:
$document->_script = preg_replace('window\.addEvent\(\'domready\',\s*function\(\)\s*{\s*\$\$\(\'.hasTip\'\).each\(function\(el\)\s*{\s*var\s*title\s*=\s*el.get\(\'title\'\);\s*if\s*\(title\)\s*{\s*var\s*parts\s*=\s*title.split\(\'::\',\s*2\);\s*el.store\(\'tip:title\',\s*parts\[0\]\);\s*el.store\(\'tip:text\',\s*parts\[1\]\);\s*}\s*}\);\s*var\s*JTooltips\s*=\s*new\s*Tips\(\$\$\(\'.hasTip\'\),\s*{\s*maxTitleChars:\s*50,\s*fixed:\s*false}\);\s*}\);', '', $document->_script);
<s-cript type="text/j-avascript">
if(typeof google !== "undefined") google.load("visualization", "1", {packages:["corechart"]});
google.setOnLoadCallback(drawChart180);
function drawChart180() {
var data = google.visualization.arrayToDataTable([["Task", "Value"],["Bolivia", 5],[" Ecuador", 5],[" Madagascar", 8],[" Guinea", 12],["Rwanda", 16],["Average", 21]]);
var options = {width: 400,height: 500,pieSliceText:"label",tooltip: {text: "percentage", isHtml: "1"},titleTextStyle: {color: "#ff9900", fontSize: "16"},title: "test",legend: {position: "right"},backgroundColor: {fill: "transparent",stroke: "#666"},fontSize: "12",fontName: "Arial"};
var chart = new google.visualization.PieChart(document.getElementById("hex_chart_div_180"));
chart.draw(data, options);
</script>
