1. minka
  3. Monday, 12 September 2016
I have placed the mod_j51icons in an article. When I go to the website the module is not showing.
I placed the following at the top of the article:
{loadmodule mod_j51icons,J51_Icons}
I use template Grafik.
File knipsel2.gif:
These icons are not showing
I have send a temp admin user.
Carian do you know what the problem is.
When I click on a icon (heart) then i want that the icons still are visible on the page, but the icons dissapear. It is an article that is showed after clicking the icon and not a menu option.
HI Minka
My apologies, I thought I updated you on this issue however we obviously haven't. Ensure that your module is set to display on the menu item linking to your article. Navigate to your icon modules parameters and set your module to display on the correct menu item via the 'Menu Assignment' tab. We were unable to locate your article to do this ourselves.
The article that is displayed is not a menu option. The article that is displayed is the link from the icon smiley. When you click on the icon smiley an article is showed and this is not a menu option.
The icons are working fine when it is related to a menu option.
The problem is with an article that is not related to a menu option.
May I suggest creating a new icons module with a new unique module position (non template position). You can then assign this module to display on all menu items. As the position is a non template position it will only display when the position loaded within an article.
