1. accs-web
  3. Monday, 13 October 2014
How do I load Newsletter Subscriber module into a Custom HTML module?
In fact I need almost exactly what you have here in the footer. I have a Custom HTML sitting in the footer-2,
next to it on the right hand side need to place Nesletter Subscriber module.
Unfortunately if I add another module it places it underneath which I do not want, I need it on the same line. Therefore,
I have created Custom HTML with a table,
in one column on right I would like to embedd Newsletter subscriber module.
The newsletter module as seen our the Joomla51 website was created by simply adding the embed code from Mailchimp (http://mailchimp.com/) in to a Custom HTML module (Extensions -> Module Manager -> New -> Custom HTML). Little or no changes was made to the code for them the form to appear as you now see it.
would you be able to send me that code
thanks
You code will be unique to your Mailchimp account. You can obtain the code directly from your mailchimp account.
