1. Oliver
  4. Thursday, 09 March 2017
I have a little issue with the behavior of the menu of new London template.
The second submenu opens submenu items in the same window not beside.
In our menu the menu is too long and then you cannot see all the items.
Developing website: http://dev.lorch-webdesign.de/_vagen2/
Example:
- click on "Bürgerservice" in the main menu
- mouseover on "KOMMUNALE EINRICHTUNGEN"
- than you see the submenu items starting with "GEMEINDE"
All menu items in "GEMEINDE" (like "Verwertungshof";) should appear beside not below!
Same with all menu items under "KOMMUNALE EINRICHTUNGEN".
You can see the correct behavior on your Habitat template on our production server: http://www.vagen.de/
Is there an easy way to correct this?
Thanks in advance
Oliver
Hi Oliver
Thank you Ciaran, I have send an email with all data.
Oliver
Thank you Oliver
The 3rd level of your dropdown menu should be now displaying correctly.
Ciar
Thanks Ciaran,
works fine :)
Is it possible, that you let me know what you have changed?
I need to transfer this to the production site after we have finished the layout.
Thank you!
Have a nice weekend.
I will apply this update to the template. Once updated you can simply re download the template and install via your extensions manager. I will drop a message here once the update is available (today sometime).
Thanks really a lot Ciaran, you are awesome :)
Hi Oliver
Our London template has been updated and is available for download!
Hi Cairan,
thank you very much - everything works fine now except a small issue with the vegas slider. The background image slider isn't available in the options of the template but the code and styles are still around.
Therefore I have an error with this script area:
<!-- Vegas Background -->
(function($) {"use strict";
    $(document).ready(function() {
        $('#container_header_slide').vegas({
            delay: ,
            timer: false,
            slides: [
})(jQuery);
</script>
As you can see, there is no delay value in the script. This causes an error.
I changed coding in the template#s index.php to this:
delay: <?php if ($headerslideinterval != '') echo $headerslideinterval; else echo('0'); ?>
I think it is an error in other templates too.
I have this little problem in Scarlet template too if I do not use background slides: SyntaxError: expected expression, got ','
See http://ostermeier-friseure.de/
Maybe you have a better idea?
Oliver
Hi Oliver
Thank you for bringing this issue to our attention.
You can actually remove all of the code under 'Vegas Background' as it is not used within this particular template. We have updated the template download, amending this issue.
thank you very much for changing this :)
Oliver
