1. Oliver
  4. Monday, 11 May 2015
Hello Joomla51 team,
hello Ciaran,
I have a little issue with the carousel module.
Scenario:
Position: sidecol_b
Nr of columns: 2
Columns per slide: 1
Url: http://winkler.oliver-lorch.de/index.php/gardinen.html
As you can see (pls check attachment or website), the second column always appears after the change.
What have I done wrong? Or is this kind of using the carousel not possible?
Thanks in advance
Oliver
Thanks Ciaran, it works fine :)
Hi Oliver
To amend try adding the following to the Custom CSS field of your templates parameters....
.sidecol_block .owl-carousel {
overflow: hidden !important;
