1. flmwebmaster
  3. Sunday, 15 September 2013
I'm using the Letterpress template and trying to have my images link to articles on the slideshow. I don't believe that the Slideshow Module has this feature. Is there another template that has this feature?
Or could you recommend another one by anyone else that would work with your template?
Thank you!
Hello flmwebmaster,
I have used the following slideshow in many instanceS and I think it has the functionality you require. Check it out here in joomla extensions directory Ari image slideshow >>
Okay I will try that extension. One other question if you know anything about the Letterpress template....I tried some other slideshow extensions that I thought would work, but the slideshow positioning for a non-Joomla51 extension put the module laying on half of my main navigation bar.
I'm sure this can be fixed with adjusting the positioning in the CSS file or how it displays, but I don't know WHAT specifically to do to make it no lay on top of my navbar. Can you help?
When you have a slideshow installed that you wish to use post a link to your site and I will take a look at the issue for you. :)
Hi John,
I thought I replied to this already, but I guess I didn't. Here is the link: http://faithlandmarks.org/about/managesiteprofile/test-site-homepage.
When you land on the page, it looks fine, but after the first slide transition then it lays on main navbar each time after that. Please let me know what can be done. Trying to finish design so I can use the new template.
Thanks! Jennifer
Hi Jennifer
.hornavmenu {z-index: 99;}
Perfect! You're a doll! Thank you so much, this worked and worked beautifully!!!!
