Warning
JUser: :_load: Unable to load user with ID: 10722
JUser: :_load: Unable to load user with ID: 8355
JUser: :_load: Unable to load user with ID: 9709
JUser: :_load: Unable to load user with ID: 9357
JUser: :_load: Unable to load user with ID: 8298
JUser: :_load: Unable to load user with ID: 9123
JUser: :_load: Unable to load user with ID: 9002
JUser: :_load: Unable to load user with ID: 6795
JUser: :_load: Unable to load user with ID: 8717
JUser: :_load: Unable to load user with ID: 8988
JUser: :_load: Unable to load user with ID: 8863
JUser: :_load: Unable to load user with ID: 8959
  1. robimac
  3. Thursday, 30 January 2014
Impulse template links in the articles do not work in internet explore 8. what can be the problem? I noticed that not even work on your demo.
thanks
Would you have a URL to an example of one of your links. Although our templates no longer support IE8, links tested on the demo appear to work without issue.
the problem is the background, the links do not work when the active background, how do I turn off the background only in ie8?
tested ie8 versione: 8.0.6001.18702
http://www.avesa.it/panificiofranchini
thanks
Try removing the following from near the end of your templates styles.php (../templates/j51_impulse/php/styles.php)..
-ms-filter: "progid:DXImageTransform.Microsoft.AlphaImageLoader(src='<?php echo $this->baseurl ?>/<?php echo $bgimagefile; ?>',sizingMethod='scale')";
Alternatively you can download the template again an install via your extensions manager which should also amend the issue.
