MENU
  1. webbie
  4. Monday, 23 March 2015
Hello, how to put panel code in the template "Lifestyle?
I made a modul gave them the class "panel panel-red invert"
and added a class in the css of the template. but there is no change?
Maybe you could have a look?
http://troostmedia.de/joomla3/index.php/piet-troost
if you go to panel 2 at the end of the page. Thank you!
You appear to have found a solution to your query?
well, i created a new style, but it is not really the solution i was looking for.
Is it possible to put the styles into the module by suffix class or something?
so it would be nessacary that youve putted it somewhere in your code.
I dont know if you have done this?
so the question is still actually: Is there any easy way to integrate this styles in
a module or somewhere else?
Thanks a lot!
Not sure if I understand you correctly. You wish to re create the panels you have on your homepage using a class suffix? The class suffix does not exist but it can be created with some custom CSS.
No i want to create the panels which are on the template "lifestyle"
like you can see it here: http://www.bootstrap51.com/demo/lifestyle/features-panels.html
Sorry to say the Joomla version of our Lifestyle template does not include the styling for these Bootstrap panels.
