1. Peters
  4. Monday, 08 May 2023
I use the LifeStyle template for a customer. Now I noticed that the menu items that I created as sub-navigation and used in the base area via module cannot be called up on the mobile device (cell phone). The navigation bar in the footer also doesn't work.
I need urgent help please.
Greetings
Verena
  1. https://schlechter.com/
Hi Verena
Try amending your existing CSS to match the height of your logo. Eg.
.logo_container {
height: 115px;
Many many thanks!!! it look#s good! It works :)
Im so happy :-)))
best regards
verena
Hi Verena
IN your template styles 'Custom CSS ', try locating and removing the following..
.logo_container, h1.logo, h1.logo a {
height: 1000px;
text-align: left;
z-index: 20 !important;
Hi Verena
Try replacing your CSS with the following...
.logo_container {
height: auto;
text-align: left;
If i remove it, it works. But than i have the problem, that die logo will be cut. That's the reason, why i write it in the Custom css.
Verena
Hey, the same problem - the logo will be cut.
what can i do? :( it's very important, to get a solution.
hello Ciaran,
it is very important for me to find a solution. My customer is quite angry that his site doesn't work and in Germany the links must always be accessible and work. Would it be possible to load a second logo file for mobile devices?
I urgently ask for help.
Greetings, Verena
