1. Ppp
  3. Sunday, 19 April 2015
I would like to add language switcher at top right corner of site - but it's not showing (nor position )
I'm using demo site for tests: http://pietron.eu/tests/lifestyle/
I switched both languade plugins, aded langs and module to position header-1 (before tried header-2) non of them works.
I tried solution from other about adding custom css code but it's not helping - can you help me with this?
I also would like to add another module just below mainmenu, working the same way (always on top of the side) - it is for filtering content by tags. I added it here, to position http://pietron.eu/tests/lifestyle/index.php/pl/j-stuff/singlearticle to hornav postion, but the menu disappeard (I also checked in template settings option to make hornav module postion).
Yes once you have the template demo installed you can edit it as you wish. That would include adding multiple language support etc.
Checking your HTML source, there does not appear to be any modules published in either the header-1 or header-2 module positions. Ensure that your module is assigned to the correct module position, it is published and that is assigned to the correct menu items (Menu Assignment tab).
And is it possible to install demo site (downloaded with demo articles) and add language after. Then just change articles? Or do I have to make clean install and install template files for having multilang site?
