1. Joeban
  3. Thursday, 12 November 2015
Is it possible to change the background color of the 3 contenttop modules different from the article background color? LifeStyle template.
Thank you in advance,
Joeban.
Hi Joeban
Try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
.wrapper_contenttop {
background-color: #cccccc;
Thank you, it works. Now I have the 3 contenttop modules background color different from the article background. Is it also possible to change the outside color/opacity of the contenttop modules to the same background color, different then the article outside opacity?
Thank you.
Joeban
Hi Joeban
I am not sure if I understand you correctly. Would you have a URL to an example of your modules so I may better understand?
So this a a screen shot from the right side. So thanks to your tip the contenttops are now in a different color then the background of the article. But now I want the space on either side of the contenttops to be in the same color and keeping the outside of the article blank/white. I hope that this is possible, if not, no worriers.
Thank you,
Joeban.
Hi Joeban
It is difficult to say without a live version of the issue. The above CSS should account for the entire 'content top' modules block which would lead me to guess that this area is part of the side column area? Sorry to say it is not possible to color the background of just the area of the side column module that is parallel to the 'content top' module without effecting the rest of the side column.
Hi Ciarán,
Thank you for your time and effort.
