1. Alexandru
  3. Friday, 18 April 2014
Anyone got a simple print stylesheet that goes well with Letterpress template?
I want a link to popup an article using print stylesheet
Hi Alexandru
Could I ask you to replace the contents of your templates component.php (../templates/j51_letterpress/component.php) with the following. Your template will then use the much imporoved bootstrap styling for your print page...
<?php
defined('_JEXEC') or die;
$app = JFactory::getApplication();
$doc = JFactory::getDocument();
$this->language = $doc->language;
$this->direction = $doc->direction;
// Add JavaScript Frameworks
JHtml::_('bootstrap.framework');
// Add Stylesheets
$doc->addStyleSheet('templates/'.$this->template.'/css/bootstrap.css');
// Load optional rtl Bootstrap css and Bootstrap bugfixes
JHtmlBootstrap::loadCss($includeMaincss = false, $this->direction);
<!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="<?php echo $this->language; ?>" lang="<?php echo $this->language; ?>" dir="<?php echo $this->direction; ?>">
<head>
<jdoc:include type="head" />
<l-ink rel="stylesheet" href="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/css/print.css" type="text/css" />
</head>
<body class="contentpane modal">
<jdoc:include type="message" />
<jdoc:include type="component" />
</body>
</html>
