Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. Thomash86
  4. Monday, 09 September 2013
hello
i´ve the letterpress downloaded- and i want to change the postion from the logo to center.
my site: http://testseite.smo-wien.at/testseite/index.php
thanks for your help
We appear to be getting the following error when we attempt to open your site along with the default Joomla template..
Die angeforderte Seite konnte nicht gefunden werden!
Now its working..
how can i change the size from the Header?
im also looking for a solution to change the size from the slideshow- so that the pictures not cited
thanks a lot!!
Your logo appears to be already centered?
In what way would you like to change the size of the header?
The slideshow dimensions can be edited via the slideshow modules parameters (Extensions -> Module Manager -> [YourSlideshow]).
yes but i did it about the x value in the settings- where i can say center?
my logo is very high so i want to change the high from the black header so the hole logo is visible
thanks
As the logo is not an inline element the option to align center is not available.
To accommodate your logo try adding the following to the Custom CSS field of your templates parameters...
#container_header {height: 382px;}
.hornavmenu {top:355px;}
#search {top: 372px;}
.logo_container, h1.logo, h1.logo a {360px;}
#logo {width: 600px;}
Thanks for your reply
now the header is bigger but i dont see the hole logo
the hole logo look like:
http://testseite.smo-wien.at/testseite/images/Bilder/logo.png
My fault.. there is one small error in the code I provided. Please replace the previous CSS with the following...
.logo_container, h1.logo, h1.logo a {height:360px;}
perfect- it works
thanks a lot for the support
You have really a big knowledge and a perfect service!!
Thanks a lot
