I use Joomla 2.5 as CMS.
I’ve downloaded the template “Letterpress”.
In every article 2 buttons are added, Vorige (previous) and Volgende (Next).
See also the added file for a screenshot.
Two questions:
1. Can I change color settings for these buttons?
2. Can I complete remove these buttons automatically for every article?
Thanks in advance for your support.
Best regards,
Jac Puts
- jacputs
- Tuesday, 02 September 2014
Two questions:
Best regards,
Jac Puts
http://www.kurven.nl/stkptest/index.php/nieuws-informatie-en-agenda-maarsstee/informatie-maarsstee
See also the screenshot I gave you already in the attched file earlier.
These buttons are added at the end pf every article.
Best regards,
Jac
Best regards,
Jac
I've put this URL now in the attched file.
Best regards,
Jac
Best regards,
Jac
You can remove these items via CSS by adding the following to the Custom CSS field of your templates parameters...
Alternatively you can turn off 'Navigation' via the menu items parameters.
To change the background color you can add the following to the Custom CSS field, editing to your own taste...
ul.pagenav {
display: none;
}Alternatively you can turn off 'Navigation' via the menu items parameters.
ul.pagenav li {
background-color: #cccccc;
}Ciarán
I did change he background of the button to maroon.
But now is the text nearly unreadable.
How can I now change that text in the button to for instance white so that it is readable.
To set the link text color to white you can also add the following to your custom CSS...
ul.pagenav li a {
color: #fff;
}Ciarán
