1. gwansek
  3. Tuesday, 29 October 2013
It appears that there is a problem with the size of the module, between modules top-2 and top-3. When you look at the demo server and go to module position it is easy to see. Is there a fix for it?
May I suggest downloading the latest version of the template and re-installing it to your Joomla installation to amend this issue.
Will it create a conflict having 2 of the same template on the site?
Installing the template again will update your current version of the template to the latest.
Just did, worked great, thank you. Love joomla 51 templates, will be downloading more.
Thanks.
