1. joonchen
  3. Sunday, 06 February 2022
Hi there,
I'm trying to setup a Joomla 4 multilingual website with the LAYLA template. I can't find the MAIN MENU module position. I would like to set the "Language Switcher" module (text only, vertical, no flags) in the main menu. Is that possible with Layla?
Thanks!
First you have to convert your menu to 'hornav'. You can do this in templates>Styles>Menu
Than put your language-switch in module position 'hornav' as well
Goog luck!
Thanks GF!
