1. Werner
  4. Monday, 27 December 2021
when clicking on the menu button in mobile view, no hint is shown, that there are submenus. Only AFTER clicking on the main menu item, an arrow for submenus is showing up. What can be done?
In earlier versions the problem could be avoided with .slicknav_menu .slicknav_nav ul {
display: block !important;
}. Not very elegant, but it worked. Do you have a solution for Layla? https://www.test.kerschbaumerhof.com/de/
This problem does not exist in NINA!
Thanks, Werner
Hi Werner
Are you creating the main navigation of your site using a menu module? If so, ensure that you have checked the Always show sub menu items option in the menu module settings.
OMG, thank you!!
Werner
