1. luisantos
  3. Wednesday, 24 December 2025
Im installing a new fresh Joomla 6.0.1 on a hosting service and when I install Layla Template for Joomla 6 and try to setup template just get a text page without format (see picture attached), any one knows why? Already cheched requirements for php, server, apache, etc and got all requirements activaded, hope can some one help me.
This is most probably not an issue with your template, but with the settings of your hosting. It may be double zip (by Joomla and by the web server) or something related to .htaccess. If you can't find out with your hosting company, you might post in the Joomla Forum.
Update...
Just activate the plugin "Behaviour - Backward Compatibility 6" and the configuration plug in and activated the options to check if is works and its done, dont know why but its works the backend template manager
behaviour / compat6
If you use extensions which are not using the current Joomla Coding standards then this plugin, when enabled, will provide backward compatibility to the previous major version, Joomla 5.
Classes Aliases to YES
Include Deprecated Classes to YES
