1. pat02
  4. Tuesday, 06 April 2021
If I edit a module in frontend and either click on save or on cancel button I get server error 403.
I'm logged in as Super User and all modules, menu items and articles are set to public.
Disabling SEF URL does not solve the problem.
It's a multi language site but I have set home menu item for each language and general Home for all languages. So I doubt multi language does cause the problem.
If I switch to Protostar template I don't get this 403 error.
Any idea why frontend editing is not working?
Thanks.
Patrick
Hi Patrick
Thank you Patrick
I have been able to replicate this issue. I notice the issue is present with both the Layla template and the Protostar template which would indicate that the issue is unlikely to be template related. In fact, the error message appears to originate outside of Joomla. Have you any server-side security enabled that may cause this issue?
You can try renaming the frontediting_modules.php file to frontediting_modules_backup.php. This will mean that Joomla will ignore this override and use the default Joomla view instead. Does this resolve the issue for you?
That did not solve the problem.
Meanwhile I did investigate further. The problem is caused by the firewall of the webhost. If there are a certain number of PHP errors thrown in a certain (short) time it will block access. I never have heard of this before. The webhost now did change something on the webserver (they did not tell what they have done) and now the problem is solved.
Thanks a lot for your help and have a nice weekend!
Patrick
Email is sent.
Thanks a lot.
Patrick
Hi Patrick
Have you since been able to resolve this issue? I have logged in to your frontend and edited and saved a module without any issue.
No, the problem has not been resolved yet. But thanks to your test I noticed, if you visit the page for the very first time editing of the modules sometimes works!
But as soon as you change the language it does not work anymore, even if you switch back to the default language (French, /fr).
or it works the first time, and after logout and login again it's not working anymore.
Can you please recheck?
You will find the login link on bottom of the page called "Private".
Thanks a lot.
Patrick
Thanks a lot for your investigations. Strange, I was not able to reproduce the problem with the Protostar template.
However, I never worked with that webhoster before. I'll try to find out if it's a security issue.
Patrick
Here is what I have received from the webhoster support:
The 403 message is caused by too many error logs from an outdated template or module or special characters (maybe umlauts) in contents inside the module or theme.
Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52
error.log
[Wed Apr 14 11:28:22.407675 2021] [proxy_fcgi:error] [pid 5671:tid 139844193871616] [client 46.127.168.57:60412] AH01071: Got error 'PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52PHP message: PHP Notice: Undefined variable: count in /var/www/virtual/[path]/templates/j51_layla/html/layouts/joomla/edit/frontediting_modules.php on line 52'
Patrick
Glad to hear you got it sorted. Still a mystery but at least you are back up and running :)
Thank you for the update.
