1. MySigma
  4. Friday, 17 September 2021
Hi Ciaran!
I'm having problems with the "Animate on Scroll" of the Layla template. Everything on your demo site (https://www.joomla51.com/demo/#layla) is working, so I'm pretty sure I messed up something. Can I send you an email with login credentials and you take a short look?
Thanks in advance,
Manfred
Hey Ciaran,
would it be fine for you? Didn't hear anything from you. ;)
Best regards,
Manfred
Hi Manfred
Sure. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
I've added the custom code but it still doesn't work as expected :-(
Manfred
Push ;-)
Hey Ciaran,
I've installed Layla with the demo content on a different server and everything is working fine. The server settings (PHP7.4,...) are the same.
I don't have any idea why it's not working on the other website I'm currently working on.
Regards,
Manfred
It was my fault... I've stupidly deactivated the "Animate.css" within the template settings. :(
