1. pitzerwm
  4. Monday, 09 July 2018
Playing with the Slide Title alignment within layerslideshow, I think that there is an issue with the "right" option. In my testing when using "Right" It actually is near center, the Slide Caption is justified to the right. When I think of "right" I'm thinking on the Right side of the image.
What am I missing?
Update: When I make the max width = 2000 then it actually right justifies to the right side of the image.
Another thing I am seeing. When I change the font size it is defaulting to 34px, which I never entered, this is my custom code:
.layerslideshow-title {
font-size: 16px;
font-family: "Arial" !important;
Update: I'm finding that I need to use the custom css box instead of a custom css file to make changes in the layerslideshow module. This doesn't seem to fix the Right alignment isssue. I see in the page code, that it says "align-items;right;"
  1. http://williampitzer.net/j51demo/
Hi Bill
Thank you for bringing this issue to our attention. This is indeed an issue with the module. We will release an update later today which will resolve this. I'll keep you posted.
Hi Bill
To amend please install the attached via your Extensions Manager (Extensions -> Manage -> Install).
You are going to love this, Ciarán. I'm doing a site with Juliet. The layerslideshow alignment (left, center, right) isn't working right,
I downloaded the latest template, dated t7/27/18 (Without any custom.css) . It appears that the alignment is aligning the caption text only, not the location. I re-downloaded the above extension and it killed the "Title", reloaded the one from the template.
Update: Went back and installed the extension that I uploaded 7/10/18 (using on the MCWT site) see attached and it now works as it does on my Kinvara site .
I'm happy but you might need to look this over..
An observation: Your sample images are 1800x717 and I have the site display width 1240 and the layerslideshow at 600 max. My images are 1200x600 but when displayed appear to be 1200x500. Is the code doing this?
  1. http://oncallinternationalsux.com/
  2. http://midcolumbiawoodturners.org/
Hi Bill
We will certainly look in to this. Thank you for bringing it to our attention!
Glad to be of help, It's always something. :o
Hi Bill
Did you have time to get this resolved?
Hi Bill
Yes this issue should be now resolved.
So the layerslideshow extension is one file and works the same in Juliet & Kinvara and others?? A link to get the latest version?
Thanks for all of the help.
For our Juliet template yes. The slideshow for the Kinvara template has different styling to match the template so no.
Ciarán, a link for the fixed Juliet layerslideshow?
I have both Juliet & Kinvara working on one version. If someone needs it, let me know. I remember this all started with me needing changes in the Kinvara layerslideshow, sorry.
Hi Bill
Please find attached the download of the Juliet LayerSlideshow module. At present the Kinvara LayerSlideshow module does not include an option to align text left and right.
