I have bought the LayerSlideshow with Collete and it works perfect in this template. Now I want to use it in the template Calibra. But there are some problems:
- The slideshow isn't in the center, but on the left. It would be also okay, if it had 100% width, but I can't find "showcase" in the modul width settings of the template.
- There is no Slide-in of the caption. It apears immediatly with the picture. I would like to have a later fade-in like it is in Collete.
- In responsive design on mobile the writing is verry thick. Can I change the Size of the fonts in responsive design for mobile?
Thank you for solutions!
Best
Harry
