I would like to change the animation speed of the layer slideshow (the text and picture should stand for at least 5 seconds). I changed it under animation speed, but it does not help.
What's the matter?
Thank you.
Assuming I understand you correctly, you appear to have resolved this issue? You have your Transition Interval set to 5 seconds (5000ms), translating to each slide been displayed for 5 seconds before it transitions to the next.
no, the issue is not resolved yet, I just played around with the settings a little, but the text in de layer show still appears too little to be read. How to change that?
ok, it seems to be working now. It always takes a while after changes are done until it show, also after clearing the cache. Might have to do something with the host provider?
