1. asiadragon
  4. Tuesday, 07 April 2020
In the layer slideshow when I add a url link from slide it does not work. Npothing happens when try to click slide
Also, the bach arrow does not work
  1. https://sproutstory.co
Thank you for bringing this issue to our attention. To amend try installing the attached update.
Will doing this update delete the existing slideshows I created?
Your current slideshows will remain however it is always a good idea to create a backup before any update.
It still does not work, still same problems, links not working and back button not working too
https://sproutstory.co/
I sent in email
Since this update all the slideshows have stopped working alltogether.
https://www.sproutstory.co
Is the Autoplay Transitions options enabled in your slideshow settings. If yes, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I have got the same problem as this.
I already added the new J51 layer slideshow but the link which was inserted doesn't work.
Edgar
  1. https://www.waterfrontappartementen.nl/
Hi Edgar
