I installed the Layla template on joomla 5 and everything was ok, until I wanted to use the Masonary layout with 2 columns. Unfortunatelly it does not work, the first article is ok, but the next ones in the 2nd column are half of their seize and are lining up one under the other (seee attached screen). My current settings are like in the second screen.
I'm using this template on other sites with the same 2 colums settings and they work well but other ones are on the j4 version, so maybe some kind of compatibility issue? I don't know, I don't have any other tricks up to my sleeve to resolve this besides reinstalling joomla and using 4th version.
Could you look at this issue? Thank you.
Edit: after futher investigation I discovered that tha article taht was messing the whole setup recived a "system-unpublish" class which I did not know where it came from, however afrer changing the date of article to move it to a different position, everything started to work as it suppose to.
In taht regards, you can please close the thread.
- ukaszw80
- Tuesday, 30 January 2024
