1. falcongr
  3. Friday, 27 March 2015
I have put the language switcher at the header-1 position at the lifestyle template but this module position is not visible when enter the responsive mode( visiting the site form a tablet or a mobile). How can i fix it.
Thank you in advance
Thank you very much , now it is working ok.
Could you try ammeding your Custom CSS to the following...
[code[#container_spacer1 {
display: inline-block !important;
}[/code]
Regarding your parent menu item issue, may I suggest the following post... http://www.joomla51.com/forum/8-commercial-templates/5991-enlighten-mobile-main-menu-not-fully-functional#13254
You can check it at http://weblime.gr/shine. I have disabled the custom css code you told me as it gives me the error I described.also I found another issue when you visit the site from a tablet or a mobile if a menu has a submenu you can't visit the primary menu destination as it is not clickable ( take a look at blog )
Now the language switcher is visible at the responsive mode but it is not working as if you try to click any of the flags you can;t as it is a part of the header and it directs you to the homepage.
To ensure this module position appears on all screen sizes, try adding the following to the Custom CSS field of your templates parameters...
display: inline !important;
