1. Edgar68
  4. Monday, 27 October 2014
i have made an multilanguage website.
build with classic template.
But the language switcher is not shown on mobile device.
I want the switcher on top, on the left site near the menu.
How can i fix that?
Gr Edgar.
I want the switcher on top, on the left site near the menu only for mobile device.
for desktop version , this is ok
http://www.strongbear.nl on mobile device I mean.
.header-1, .header-2 {
display: inline !important;
To re position the module you can also add the following...
.header-1 {
left: 0;
top: -50px;
Hi Carian,
It makes no difference.
Hi Carian
Do i have to place it in each template?
all 4 languages?
Now i only placed into the main template.and that makes no difference.
Gr. Edgar
Hi Edgar
Yes you will have to place it in each template style you wish the CSS to effect.
Hi Carian,
It's still not working.
Gr. Edgar
You had added a link to a javasript CDN in to your Custom CSS. This link should be added to the Custom Code fields not the Custom CSS. Removing this code allows your CSS to work correctly.
Thank you very much Carian.
The problem is solved !!!! B)
Hi carian
I've got another problem now.
when you go to http://www.strongbear.nl on mobile device,
and you open the menu, the laguageflags are shown, through the text of contact menu.
Those two items stand together, so one of them is not working.
The language switcher does not remain displayed at the top.
Can you help me with that?
Gr Edgar
Have you amended this issue as your language flags appear to be now working fine on all devices?
Hi Carian
Only for television 720d & 1080d it is ok.
http://quirktools.com/screenfly/#u=http%3A//www.strongbear.nl/nl/&;w=1280&h=720&a=4
http://quirktools.com/screenfly/#u=http%3A//www.strongbear.nl/nl/&;w=1920&h=1080&a=4
Not for tablet, mobile and desktop
http://quirktools.com/screenfly/#u=http%3A//www.strongbear.nl/nl/&;w=533&h=853&a=24
You have to click on the menu at the right side, to see what i mean.
Edgar
Hi Edgar
Your site appears to be offline? May I suggest sending temporary access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
For this reason you can not place these flags in the menu area. Your only option is to place them under the mobile menu button as they will always animate down with the menu.
Hi carian,
How can i fix that ?
Gr Edgar
Try removing the following from your Custom CSS field...
.header-1 {
left: 0;
top: -50px;
