http://www.bargoddess.com (any page there has the mysterious code on top.)
How it happened is embarrassing. I kept getting errors from Google & Bing saying that my homepage had no title. If I changed it using Menu, it would change the menu and push it all out of whack. I thought possibly if the meta title was included on the template... So, I am the one that screwed it up.
I purchased SEO Boss Pro, which promised to put a title and meta tags on the home page, but unless it is my cache, I haven't detected a change. However, support there got back to me and said, "I see that the HTML structure are broken
"<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "
http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html >language; ?>" lang="en-gb" >
<head>"
with a follow up that said "I think I can fix this with ftp access. I need look to the template file (/templates/j51_specialize/index.php)"
Hmmm...???
~Kat
