1. Stefunk
  4. Friday, 30 March 2018
Hello Ciaran
I have 3 questions about the Kinvara template...
1. How can i setup the width of the article / main container as in the demo that the hole content with all modules is in 1140px? I have a background selected in grey, the article container is white and is in 100% width. But in the template features i cant setup the manual width or maybe i dont find it...
2. How can i reduce the padding between Showcase and article / main container, if i dont use any top modules between them? I can see the background between showcase and article / main container.
3. How can i hide the title attributes for each menu entry link? When i type a title its always visible, not only by mouseover. I think i had this problem also in the London Template.
Thank you for your help and happy eastern :)
Steve
  1. http://salzgrotte-eitorf.de
sorry, question 1 and 2 i found out by myself. It has something to do with the j51 slideshow plugin. If i activate the slideshow plugin, the css is somehow different and the main container is in 100% width...
If i only load one picture into the slideshow module, its like it should be.
Maybe you can give me a tip, why its like that?
Hi Steve
Your site appears to be offline. Could I ask you to send temporary access details to info@joomla51.com and we will examine this issue further. For our reference please paste a URL to this post in your email.
Thank you Steve
To hide the title attribute you can add the following to the Custom CSS field of your template settings..
.hornav > ul > li > a::after {
display: none;
Would you have a URL to an example of your slideshow and I will examine this issue further?
Hello Ciaran
Thank you for your help, the css code works fine.
The URL is the same, the slideshow (Home_Slideshow, ID 93) is placed in the "home" link in showcase modul position. But nothing to see.
If i use showcase-1a module position for example, i can see it, but than the design of the template isnt right and i see all pictures at once.
So i guess showcase-1a isnt the right module, it must be showcase as in all templates from you.
Steve
Hi Steve
As your slideshow is not been displayed, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
Hi Steve
Checking your module image module placed in the showcase-1a module position I noticed that it is not assigned to your Home menu item. I have amended this and it is now displaying.
