1. sf888
  3. Monday, 09 October 2023
Hi, I did purchase the Kinvara template just recently and I cannot get the slideshow to work properly. In the beginning it did show the first slide only, but now, not even that.
I read through the install document, I read the issue page, I reinstalled the module, no success.
Would be glad to find out, what is wrong and how to correct.
The second issue I am facing in the category blog layout of just one menu: the 3 columns are not side by side. I did amend the custom ccs and it was ok, but after switching the template style, adding the custom css as before, on this one page it is again not showing properly.
  1. http://2023.stefanie-wuest.de/index.php/interim-wohin
  2. http://2023.stefanie-wuest.de/index.php/programme
Note the second URL is returning a 404 error.
Hello Ciaran, I did resend the credentials as a reply a while ago, I would appreciate your feedback to all the mentioned issues.
Thank you. Stef
As a rule, we would usually not store users access details. Could I ask you to resend your details to the email mentioned and we will examine this issue further
Thank you for the details however we are getting the following notice when we attempt to log in..
I have the same issue as this, even though I have installed the version that came out earlier today.
The problem is the same as I had a couple of years ago, as specified in this post: Previous post
I will post access to my site. ;)
regarding the slidesow I had the sameissue and found a solution like this.
Add to the Custom CSS of your Template Stile
#container_showcase1_modules .info.wrapper960 {
Thank you DSWrights, that did the trick!
