1. eumel7
  4. Wednesday, 07 December 2022
In the module position SideCol 2a and 2b I have displayed a small module next to the content. when I choose the mobile view, the sideCol position doesn't move under the content, but stays next to it. I can't find any setting how to do this.
What else is important:
- Template Kinvara installed with sample files
- Template styles "Homepage" and "Default" both tested
- Setting layout option: CSS / SCS /CSS (width 25% each) tried everything
- The original menu entry of your template "Layouts" doesn't work either! (currently displayed on my website)
- It doesn't work for the sidCol1 position either.
- Setting: "Sidecolum Positioning" : Before or after Component, tried everything.
Now I don't know...
Link: My menu item "Home" (Hompage Styles):
http://joomla4.ferienwohnung-deubach.de/index.php/de/
Link My menu item "Holiday apartment" :
http://joomla4.ferienwohnung-deubach.de/index.php/de/unsere-ferienwohnung/das-ist-die-wohnung
Link: Your original menu link: "Layouts":
http://joomla4.ferienwohnung-deubach.de/index.php/de/layout-options/content-sidecol
I have sent the access data to the website. if they are needed ([email protected])
  1. http://joomla4.ferienwohnung-deubach.de/
Thanks.
I now have the code below in the respective template styles:
Added "Responsive Option" -> Phone (L/scape) Custom CSS.
Also set the SideCol-B width (%) to "36" under: "Layout Option". It fits my cell phones there.
Hi eumel7
#container_main #main {
flex-direction: column;
Does this resolve the issue?
First of all thanks for your answer.
The code works very well in phone portrait mode.
It looks a little weird in Phone (L/scape) mode...
(The code was entered in the general settings of the custom css not in the custom css of the responsive options)
Would only applying a single column to the phone portrait view give you the desired result? If yes then can try replacing your CSS with the following...
Thanks for the info again.
I don't quite understand what that means. Yes I only need one column next to the content. It doesn't work that well with the 440px.
I saw that the calendar had a fixed width in pixels, I changed it to 100% and I can live with it in (L/scape) mode now.
I have now taken the 767 px width in the custom css code
Only the module title is now truncated in (L/scape) mode
see image
Thank you for detailing. I now realise your issue.
Probably the easiest solution would be to increase the media query size so the single column would be displayed on landscape module. I am not sure if this would be suitable?
Eg.
Note that as the above CSS is already wrapped in a media query, you can add this to the Custom CSS field in the Custom CSS tab.
No, unfortunately not.
There are also differences in the display, depending on the size of the screen. I think I can live with that if I leave it in the responsive options.
I don't know if there will be errors in the future.
